  • 1 month later...
No luck at those sites. Anyone else have suggestions. I would even take a generic one. My duck tape seat is just plain ugly.
you could do what i did....
my duct tape to seat material ratio reached critical mass the other day so i took the seat off of its hinges.
I cut a pair of jeans' leg off, split it up the middle. then i wrapped it around the seat and used a screw gun to put very short screws into the underside while pulling the denim tight and worked my way front, then back, then each side little by little all around.
I used jeans because They were black, they had a hole in the ass so i couldnt wear em to work, and im a cheap bass stirred.
if you want I could post some before and after pics so you can see what i mean.
On mine, I took the seat off, and carefully peeled the old seat cover off, duct tape and all. Then I sliced it apart to make a pattern to make a new cover out of fresh vinyl from the upholstery fabric store. Only 2 seams to sew and it went back on easily. Of course, this method requires ability to sew, or least finding someone else who can.
Though if I were buying a new one, I'd probably look at JP Whitney.
I know Ebay is an easy answer but....
...have you thought about setting up a saved search on Ebay? You can have it email you when the exact item is posted that you need. It saves you from checking periodicly or missing out on a great deal. I seem to save the most $$ via eBay and have found some real treasures on there for my oldies.
