yamaha sr 125 valve clearences
im after a bit help. i need the valve clearance settings for my yamaha sr 125. It starts and runs fine but its quite tappety.
if anybody can give me settings for inlet and exhaust valve,it would be great.
The valve clearances are Inlet 0.05 - 0.09mm or 2 to 4 thou and Exhaust 0.11 - 0.15mm or 4 to 6 thou with the engine at TDC on the compression stroke with the engine cold. Tony.
thanks for the infomation. ill set them on saturday morning and try it. thanks again Anth. :D
