2000 R6 not selecting gears
Hello i have a 2000 R6 only 8K miles The gears have always been a bit clunky but recently when going up the gears i have to lift toe twice to get it to change , the first time nothing happens and it goes in no problem the second time . not crunching or load , its not like that going down gears, not to good for hard accerelation as it takes two tries to get next gear any thots or info would be brilliant thanks very much
worried yam owner
[hi, these suffer from gear shift shaft springs snapping,is the gear lever all floppy ? other than that you prob looking at a gearbox strip to find fault. easy job when you know the bike..
worried yam owner
