Hi new member just bought XS650C been in storage 10 years 4500 miles
put in new battery electric start doesnt do anything 1 indicator comes on
there are a few disconnected wires in the headlight from the LH handle bar switch
no spark or power to coils or points I looked at a black and white wiring diagram and its not helping
as colours seem to change can anyone help with a color drawing or tell me where the flasher wires are supposed to plug in from the switch and the front flashers.
Why no spark ? what should I check
Thanks Mike
theres a load of stuff that cou;ld be wrong, check the fuses, solonoid(where the red battery wire goes), try checking the ignition switch is working, too much to list, try this link,here, wiring diagrams,here, hope this helps its about the most informative xs650 forums on the web. also here
my guess would be the kill switch is unplugged in headlight shell, The basic wiring chart is the same up to 79 after that its different, the only difference in the 76 is addition or relocation of warning light crap or safty relays. Do you get elect start if you jump the solonoid? What happens if you kick it?
Hi thanks both for the help
it was a combination
red /white plugged in wrong connectors kill switch not conected etc etc all in the headlight
got sparks and fired right up
thanks for the help
Mike
