April 14, 200916 yr hello bike was running fine today and it started bogging down... i checked the carb and it was fine put it back on started it up and it will idle and shit but when u rev it nothing happens??? it just bogs down and dies any ideas?
April 14, 200916 yr Author there is a great fuel flow from petcock i just dont understand gas flow seems good it idles fine but once i go to give it gas aka rev the enginge it just bogs down and stalls unless i let off the gas
April 15, 200916 yr Moderator its time to strip & clean the carb, check for water in the float bowl or blockage in the main jet, failing that do a general strip and clean routine using carb cleaner (avoid this on rubber parts) and compressed air. This is a useful read Here
