Have i Broken it ??
I have bought a seondhand thunderace and after getting used to it, i decided to pull a few Gsssssss making a chav look a tit (he was boxing me in on every vehicle we passed on a dual carrigeway) so when the oppertunity arose i shot of and made him a distant memory. Any way now she sounds like she has blown exhust. still running OK but a few Db's lower. Have i poped something ???
sounds like exhaust has got a hole in it might be able 2 weld it, but i should imagine you need new down pipes if they have blown when giving it some beans!
i would be surprised if you had holed the exhaust caning it, maybe the exup has gone out adjustment (it has a large effect on the exhaust tone) or the joints have a leak.
put you hand over the end of the can/s while it is running, ithe bike should cut out or feel a load of pressure from the exhaust and if it is leaking you will be able to hear it.
if you can hear a blow run your hand about 2 inches away from the exhast while it is running and you should feel where it is coming from (carefull though, they exhausts get very hot)
Ken
i have done a quick check for leaks and didn't find any so i am hoping its not one i haven't found. But i have booked it in for a going over. thanks
The guy at DKs said it's just because it's a race can and it will sound that way and perhaps get louder. not the best of news as the local constabulary use the A50 as a hunting ground. i've heard about this EXUP valve but don't have a clue where it is, also i found a part on E-Bay thats looks worrying called an exhaust pump. scarry stuff.
I've got it by jove !
you've blown an eardrum ? :mellow:
Ken
Tried the hand thing today and it did cut out so that's good i guess, she moaned about starting afterwards though. i still can't find any obvious blowing on the system. i'm thinking she is just a loud mouth beast and likes to sing about it.
its not that complex, its a moving plate that varies the back pressure in the header pipes. its located in the collector box at the low point of the exhaust system. It is operated by a servo next to the carbs, which moves two cables which open and close the valve.
EXUPs can sieze and they need a little TLC to keep them working well.
