I have a YZF 750 (1992) and want to find out if wheels of an EXUP, FZR/YZF 600, or R1/R6 wheels would fit (inc disks) Does anyonee know?
Many Thanks
Thunderace rear wheel is a straight swap
The later FZR1000 Exup Foxeye model front wheel is a straight swap.
Exup F+R discs are the same as YZF750.
Wheels are similar.
To use the exup wheels in the YZF 750 you will have to change the Sprocket carrier Bearing and spacer along with the wheel bearings and spacer inside the wheels to suit the larger diameter YZF's wheel spindles.
I put Yzf750 wheels in an 89 exup many moons ago by this method.
Also put the six speed gaerbox from the YZF 750 into the exup and it made some difference to the top end.
