April 11, 200916 yr my son has a tzr 50cc 2 stroke i want to change the gear box oil but dont have a manuel can i just use 10/40 engin oil what i use in my bike ?
April 11, 200916 yr Moderator GENERAL SPECIFICATIONS SPEC 2-1 Model TZR50 / X-POWER Model code number 5WX Frame serial number Yamaha UTLRA031000000001 MBK UTLRA032000000001 Dimensions: Total length 2007 mm Total width 675 mm Total height 1065 mm Height of the seat 815 mm Distance between axles 1330 mm Minimum ground clearance 144 mm Basic weight: With oil and full fuel tank 124.2 kg. Minimum turning radius 2900 mm Engine: Type of engine 2 stroke, petrol, liquid cooled Admission system Reed valve Cylinder arrangement Single cylinder, slanting forwards Cylinder capacity 49.7 cm3 Bore x stroke 40.3 x 39 mm Compression ratio 6.85:1 Starting system Electric Lubrication system Independent lubrication Motor oil Type Yamaha 2 stroke oil or oil for air-cooled 2 stroke engines Capacity 1.35 L Transmission oil: Type Engine oil SAE 10W30 SE type Capacity: Regular oil change 0.75 L Total amount 0.82 L Capacity of coolant: Including all routes 0.7 L Air filter: Type Damp element SPECIFICATIONS GENERAL SPECIFICATIONS
