Hello to you all.
I have just purchased a YB100 to use as a work bike.
The bike wont go over 45mph,i thought these were good for around 60-65mph.
I have looked at the baffel and gave it a clean up took the head off and looked at the piston, it really wasnt coked up at all
I amnow thinking it maybe a carb issue.
Any ideas or advice greatly appreciated.
Cheers
does it bog down when you open the throttle, or overheat?
need a bit more info on how it runs before we can diagnose the problem.
my DT50 will do 45 but i have had to modify the engine and add new sprockets, so 45 for a vintage 100 may not be that bad
Thanks for the reply, it doesnt bog down or overheat, it gets to 45 and thats it no more.
Maybe you are right its top end is 45mph.
Hello to you all.
Cheers
Hi Nigel,
The YB100 was only good for about 60 max ..... to ensure the bike is in top fettle do the following :- Set the ignition timming to 1.8mm btdc, set the minimum oil pomp stroke to .04 mm or less. Remove the silencer and remove carbon deposits until the silencer weighs less than 1kg, check the exhaust port for carbon deposits !! I could go on but I would guess there will be more helpfull posts than this !
Regards Jim
Hi Nigel,
Regards Jim
You should get 60mph out of it and 70mph down the hill with the wind behind you - I know I have!
You will need to check and set/adjust the following:
Carb settings
Oil pump settings
Points setting(check points condition)
Baffle condition
Air cleaner
Needle valve setting
I would also replace the spark plug (NGK B7HS) they do have a tendency to eat them!
You should also check out the clutch - could be why its not getting up to speed - worth a look.
If you need the tech settings I will post them for you.
Good luck - let us know how you get on.
:D :D :D :D
Thanks for the replys it is much appreciated, i will let you know how it goes.
Thanks again
Nigel.
Does anyone know where i can buy a replacement exhaust baffel for the YB100.
I've had a slight accident involving a car wheel and the baffel .
Cheers Nigel
Cheers Nigel
Whoops! :o
Main dealer around about £30 unless you are lucky enough to pick one up off ebay.
Good luck
:D :D
Cheers Nigel
Hi nigel,
you can pick up a whole silencer on ebay for less than £50 which if fitted will save you having to decoke it and a new baffle in the package !
Regards Jim
