Hi all
I just got my new/second hand XJR1300 (not an sp)
I also got the twin headlamps that fit straight on to it. I think they would look real good on it.
The question is what happens to all the wiring and plugs that you find in the original single headlight ?
what do you do to make them look good without all that excess wiring hanging around
many thanks
Dr Devious :blink:
i suppose its like my ybr125, with (literally) a web of wires in there!! i was thinking of dominator headlamps (the twin ones), and i was contemplating that i could just pull the wire back to where it comes from (under tank-ish) and only leave enough wire there for a full lock on the steering either direction, then get some sort of wire tubing (like a tube with a slit going down it) and use that instead.. a bit of insulation tape, matching the tube in colour to seal the slit, and hey presto :D
