punisher_uk Posted April 3, 2009 Posted April 3, 2009 hi i recently aquierd a 50cc for my son I've ridden it a few times rear suspension seems very hard dose the same rule apply to the sag and as off road bikes i no the tiers are very slim but it tramlines ie( follows every couture in the road ) tarmac joins and white lines it really moves spooks you a little so any ideas after the rear sus ???
wild foamy Posted April 3, 2009 Posted April 3, 2009 white lining could indicate low tyre tread? give that a check as the legal limit is 1mm for motorcycles and "visible tread" for scooters suspension is probably designed to be hard because its a race rocket style bike, on my DT and most other trials bikes it is a lot softer because its designed for rough terrain
punisher_uk Posted April 3, 2009 Author Posted April 3, 2009 white lining could indicate low tyre tread? give that a check as the legal limit is 1mm for motorcycles and "visible tread" for scooters suspension is probably designed to be hard because its a race rocket style bike, on my DT and most other trials bikes it is a lot softer because its designed for rough terrain ok had quick measure and ther is 10mm of static sag and around 15mm of rider sag so that needs sorting thers not alot to play with on thes bikes very basic so preload is all i can alter on the rear front well same again no adjust, i think its to soft can not bottom it out but the rebound is to quick so heaver oil i think or start from scratch and find the stranded oil and amount and work from ther so anyone now the original oil weight and amount for front forks on a 2002 tzr 50cc??????? can not find a manual anywhere oh btw tires are fine tread wise maybe a little hard will check tomorrow
