Hi i`ve solved the sticking problem but my tzr 125 just wont idle when the choke is off idles fine with the choke on though.It just keeps cutting out at a stop please could anybody give suggestions on what this could be ?
thanks pete79
thanks pete79
Hi Pete,
I would guess that the bike dont need that much choke if the bike is a late 80's early 90's TZR but on reading the post it idles it idles with the button in the out position & not the in position ? To set the idle up do the following :-
1) Run the engine until warm (dont worry about the choke position)
2) insure the choke it off (pushed in)
3) Adjust the idle via the throttle stop screw until the tacho reads 1,250rpm
4) screw in the mix screw and back it out 1.5 turns (the engine may stall at this point)
5) if the engine does not respond or idle very well at this point disassemble the carb and clean it out & retry
I guess you have done the normal checks of compression, Spark plug & exhaust system (TZR has CDI fixed ignition, so there is no need to check this, unless you have a misfire.).
I know it sounds silly but could you be using the choke the wrong way round ?
Regards Jim
Hi Pete,
Regards Jim
hi jim
Thanks for the reply i`ve checked compression and new plug not yet had the exhaust off but will do tomorrow
and will follow the steps you`ve posted and see how it go`s thanks again.
pete
