In the manual I read: Headlight "sealed beam" 50W/35W.
With mine there is a plane reflector and it is not worn, with a complcated lense.
The H4 bulb in place looked worn and gave no good light.
So I replaced with OSRAM Bilux H4 NIGHTBRAKER 60W/55W. ("90% more light" ??)
The low beam shines OK, but the high beam goes everywhere except where I expect it.
What might be the right bulb???
dont know what the right bulb would be, but i took out the small 6.75" headlight, removed the trim ring and stuffed a 7" Hella e-code headlight in there. I put in a sylviana xtra-vision 60/55 bulb and overall its a huge improvement. hope this helps.
