Racing Variator
Hi, i have an Aerox 50 sat in the garden and I want to put a polini racing variator kit on it. Now i've been told that if i put a new variator on it then i would also need to change the clutch to a new racing one aswel.. is this true? any help would be appreciated, thanks.
i doubt you will NEED to put a racing clutch on it, but adding lighter rollers and stiffer clutch springs would be ideal because it would engage at Higher RPM
Thanks, ill keep it in mind :rolleyes:
  • 4 months later...
No you dont have to change the clutch, the clutch is usually the last thing you change. but yeah harder clutch spring shoud do the job. :huh::D
  • 10 months later...
thats shit whoever told you that, buy a 9 rollev variator it comes woth tighter clutch springs, you dont need to change your clutch unless it has worn out or your raceing it and want a lighter 1wich wud last about 2 mins
