March 29, 200916 yr Hi, i have an Aerox 50 sat in the garden and I want to put a polini racing variator kit on it. Now i've been told that if i put a new variator on it then i would also need to change the clutch to a new racing one aswel.. is this true? any help would be appreciated, thanks.
March 29, 200916 yr i doubt you will NEED to put a racing clutch on it, but adding lighter rollers and stiffer clutch springs would be ideal because it would engage at Higher RPM
March 29, 200916 yr Author i doubt you will NEED to put a racing clutch on it, but adding lighter rollers and stiffer clutch springs would be ideal because it would engage at Higher RPM Thanks, ill keep it in mind
August 20, 200916 yr No you dont have to change the clutch, the clutch is usually the last thing you change. but yeah harder clutch spring shoud do the job.
July 13, 201015 yr Hi, i have an Aerox 50 sat in the garden and I want to put a polini racing variator kit on it. Now i've been told that if i put a new variator on it then i would also need to change the clutch to a new racing one aswel.. is this true? any help would be appreciated, thanks. thats shit whoever told you that, buy a 9 rollev variator it comes woth tighter clutch springs, you dont need to change your clutch unless it has worn out or your raceing it and want a lighter 1wich wud last about 2 mins
