March 27, 200916 yr Picking brains again.. I haven't been let down so far very impressed with the knowedge out there My latest problem is the spindly 34mm forks on my XS500. I don't want to pay £150+ for a re-chrome (unless you know anywhere I can get it done cheaper!!!). Is there another model that shares the same headstock dimensions as mine but will allow me to use bigger diameter forks? Does the LC range use the same yolks (tripletrees in US ) with 35mm legs for example? I would be happy to use the 34mm legs but it seems like the larger sizes are much easier to find
April 1, 200916 yr The XS650 used 35mm forks i think, at least in the later models. Maybe that would work for you? Picking brains again.. I haven't been let down so far very impressed with the knowedge out there My latest problem is the spindly 34mm forks on my XS500. I don't want to pay £150+ for a re-chrome (unless you know anywhere I can get it done cheaper!!!). Is there another model that shares the same headstock dimensions as mine but will allow me to use bigger diameter forks? Does the LC range use the same yolks (tripletrees in US ) with 35mm legs for example? I would be happy to use the 34mm legs but it seems like the larger sizes are much easier to find
May 19, 201015 yr any idea on the specs of the springs for the XS500? I'm looking for new ones, and can't find what size I need.
January 30, 201213 yr Late answer , perhaps useful to others: The '76 (XS500C) and later used 35mm forks, should be easy swap.
