March 26, 200917 yr ok so i have put on a vm24 roundslide mikuni onto a dt175e. the probelm is, im a total newb to bikes (only worked on trucks until now) and i have no idea how to adjust this thing so that it runs right. a fellow yamahacluber informed me on the settings: Main Jet 140 Needle Jet 0-2 Jet Needle 4J13 Clip posn 3 Pilot Jet 22.5 Air screw 1 14 turns out Float level 21mm but that doesnt really mean alot...so could anyone out there walk me through this? maybe even a couple pictures? thank you in advance.. rob
March 26, 200917 yr ok so i have put on a vm24 roundslide mikuni onto a dt175e. the probelm is, im a total newb to bikes (only worked on trucks until now) and i have no idea how to adjust this thing so that it runs right. a fellow yamahacluber informed me on the settings: Main Jet 140 Needle Jet 0-2 Jet Needle 4J13 Clip posn 3 Pilot Jet 22.5 Air screw 1 14 turns out Float level 21mm but that doesnt really mean alot...so could anyone out there walk me through this? maybe even a couple pictures? thank you in advance.. rob Lets start here, do you have the old carburator slide, if you do you should have the correct jet needle.
March 27, 200917 yr no unfortunetly i bought it without a carb or any carb components Where are you located.
March 27, 200917 yr south boston, mass why? If you want to send me the carburator, I will set it up for you. I am in Georgia.
