dt175 jetting
ok so i have put on a vm24 roundslide mikuni onto a dt175e. the probelm is, im a total newb to bikes (only worked on trucks until now) and i have no idea how to adjust this thing so that it runs right. a fellow yamahacluber informed me on the settings:
Main Jet 140
Needle Jet 0-2
Jet Needle 4J13 Clip posn 3
Pilot Jet 22.5
Air screw 1 14 turns out
Float level 21mm
but that doesnt really mean alot...so could anyone out there walk me through this? maybe even a couple pictures? thank you in advance..
rob
Main Jet 140
Needle Jet 0-2
Pilot Jet 22.5
Float level 21mm
rob
Lets start here, do you have the old carburator slide, if you do you should have the correct jet needle.
no unfortunetly i bought it without a carb or any carb components
Where are you located.
south boston, mass why?
If you want to send me the carburator, I will set it up for you. I am in Georgia.
