mot?
botty92
This post is 5723 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
chain and sprockets, wheel bearings, wheel tread, shocks (check for pitting, leaks e.t.c), check calipers for leaks, brakes are functioning, the electricals are working,
as long as your bike is in pretty good shape you should be fine
According to vosa.
for motorcycles...
Lights - condition, operation, security, and correct colour of headlamp(s), rear lights, indicators and reflectors. Also the headlamp(s) will be checked to see if the aim is correct
Steering and suspension - condition, security and operation including: forks, mountings, controls, bearings, etc
Horn - correct operation and the right type
Exhaust system - complete, secure, correct type and not too noisy
Side car - includes checks on: attachment, suspension, wheel bearings, wheel alignment, lights and tyres
Wheel alignment - correct alignment of front and rear wheels
Frame - free from cracks, damage, distortion or corrosion which is likely to affect steering or brakes
Wheels and tyres - wheel condition and security, tyre condition, size and type, and tread depth
Brakes - condition, operation and performance (efficiency test),and brake controls
General items - condition and security of final drive, footrests and seat
I found this on the Directgov website under MOT if you're wondering.
