March 24, 200916 yr hi guys Could anybody tell me what carb is on my dt 175 (1975) and possibly where to look for a new one. cheers Ray
March 24, 200916 yr Moderator hi guys Could anybody tell me what carb is on my dt 175 (1975) and possibly where to look for a new one. cheers Ray Probably next to a pile of rocking horse siht, only kidding but they are increacingly rare, any of the auction sites really. Would need the engine no to be exact with which carb you have and that will be the trouble with any that turn up you cannot be certain that its the right one. Going on your previous thread are you sure another carb will cure your ills, it would be far easier to fix the one you have i would have thought, it may even be something else like electrics or crank seals. As far as it goes carbs very rarely actually wear out. The stuff in them does like jets and needles etc and that can be fixed. Oh and Ray, note to self, add the A on the end of your bike name.
March 24, 200916 yr but they are increacingly rare Yeh every word that cynic says is is true " But i did see a new carb on fleabay . last year [german seller] £ 90. It was the real deal [ black pull-up choke] .."patience is vitue"
March 24, 200916 yr This site has alot of info and they carry alot of old new stock DT Parts. See wiring diagrams, part placemsnt photos etc, etc, etc. This site was alot help when I was refurbishing my 1975 DT 400C Good luck. http://www.powerpartsplus.com Visit this Website
March 24, 200916 yr This may be an alternative solution: VM24 copies made for the Enfield, couple on the bay.....
March 24, 200916 yr Also................ There are a couple dt125 carbs (same type) on the bay also, will just need appropriate jetting............
March 30, 200916 yr Author Also................ There are a couple dt125 carbs (same type) on the bay also, will just need appropriate jetting............ Ally Thanks for the info I have put in a bid, fingers crossed should be able to make one good one up out of that lot Ray
