I've ordered some fork oil seals for my YBR125ED, since mine started to weep. I cant seem to find the correct oil levels for each fork, or the ideal oil type. If anyone knows, I'd appreciate it!
John
You need to refill with 154ML per leg of 10w fork oil or measure the fork oil level which is 166mm from the top of the fork with the fork vertical with the springs removed and the fork fully compressed. Tony.
