Posted March 21, 200916 yr hello most of you might be aware iv just got a honda hornet 600 and today was my first day out on it restricted after having a really good day i stopped at a service station when i came back i found i had snapped my key ( i no its a honda and im asking for help on a yamaha forum) after a hour of fiddling and fettling the broken half of the key into the igntion i managed to get it started thank god or it would have been a really really long walk! do i have to replace the barrel now? rough cost? or is there any alternatives? any help would be much appreciated
March 21, 200916 yr did this once in a car we took the barrel off and we used a pin in the bottem of the barrel we put masking tape round the pin so it did not pierse your skin and push the broken key out of the barrel its really fiddley but we got there in the end or just buy a new barrel good luck
March 22, 200916 yr Author did this once in a car we took the barrel off and we used a pin in the bottem of the barrel we put masking tape round the pin so it did not pierse your skin and push the broken key out of the barrel its really fiddley but we got there in the end or just buy a new barrel good luck thanks mate il see what i can do tomoz
March 22, 200916 yr Moderator Bad luck that Mikey, but you must have known the key was cracked and carried on using it!! Dont know how you will get out of this one but if it were me I would be trying to remove the broken piece, BUT...have you got a spare key or at least the key number?
March 22, 200916 yr shame ya did this my mate did the same once btw the hornet isnt a offroad bike so mods stick it in the right section
March 22, 200916 yr I've had to do this many times for customers. What I do is this: I have a selection of very small HSS drill bits and I drill a 1mm hole down through the key blade. I then syringe a tiny amount of Araldite type glue into the hole and push in a piece of electrical wire into it. I leave it to set for about ten minutes and then pull. Hey Presto! The key comes out no problems.
March 22, 200916 yr Author I've had to do this many times for customers. What I do is this: I have a selection of very small HSS drill bits and I drill a 1mm hole down through the key blade. I then syringe a tiny amount of Araldite type glue into the hole and push in a piece of electrical wire into it. I leave it to set for about ten minutes and then pull. Hey Presto! The key comes out no problems. that sounds like a really good idea but its a inch deep into the igniton it didnt have the curtosy to snap off flush lol
March 23, 200916 yr Talk to an auto locksmith. They can extract the broken key and cut you a new one for a few quid. I have the kit to do it myself, but you're a bit far.
