I removed all fairing and instruments up front When i removed connectors for the instruments and rewired and tied everything up The starter switch does not work new lights all work and bike will start when i push it. Looking at wiring diagram in Clymer manual I see a reed switch was something i cut wires on it was up front in instruments. It has a ground wire and a white/green wire which goes back to the relay assembly. Is this the source of my problem and how do i fix this situation.
Thanks for any advice from the group.
