I love my 1300, but have a large foot and there is NOT enough room between the heel and toe levers for my riding boot (55).
I have searched around and have not found any one else mention this issue, nor have I seen any replacements/solutions.
Currently I have to make a lot of foot gyrations to shift. I'd love to keep the heel/toe style but need more room between the levers.
Any ideas?
Thanks in advance!
Any ideas?
Thanks in advance!
Can you not just move the lever so the front is high enough to slide your toe under... I have UK size 10 and it works fine
  • 3 weeks later...
My US size is 15, so about a 14 UK, -- just not enough room. I end up resting either the front or back of my foot on the shift lever of the last shift that I made -- shifting up leaves my heel resting on the back lever, down my toe on the front lever. Would really like to get some more room though...
Can you not just swap the rocker out for a normal shifter, or lengthen the rocker arms?
