Has anyone tried castor oil in fuel to get that tremendous 'R' smell (my speedway days). If so, how much did you use and did it work?
does this really work? I've heard of putting in small amounts Acetone helps improve things performance wise
I've still got an old gallon steel can of R40 in the garage. I used to put a capfull in the FZR1000 Genesis tank when going for a good blast. All the bikes i've had since then have been bikes that ive been scared of gumming the carbs up on. So the best part of a gallon is still in the garage.
I 'almost' get that smell every time the bike fires up. The oil tank is filled with castrol TTS, the tank is filled with sheel v-power and the two stroke engine kicks out a lovely smell :D .
tremendous 'R' smell --------------------------------------------------
-- :rolleyes::rolleyes::rolleyes:
I"v been blawing about this ever since i joined the Forum ... :D U can still get it here .herehttp://www.racelubricants.co.uk/product.asp?strParents=91&CAT_ID=113&P_ID=462
