March 16, 200916 yr Hoping someone might be able to help with this one. Have an 07 xmax 125cc scooter. Great bike except knocking noise from front end. remove front mud gaurd and noise disapears. Original bolts were siezed so I drilled them out and repplaced them with s.steel bolts. Nothing on the gaurd is loose and there are no signs of rubbing. have even put rubber wasers between forks and gaurd and the knock is still there. Maybe someone else has had the same problem and found a solution. Cheers Bob
