SR125 clutch issue
Hi all,
I've recently refitted an engine and since I connected the clutch cable back up I've had problems in getting the clutch lever to 'spring' back - there doesn't appear to be enough tension - I've tried tightening both the handlebar lever adjuster and the adjuster nearer the engine but with no joy - any suggestions?
Hi all,
is the clutch disengaging?
did you lose the ball bearing along the end of the clutch rod?
is the clutch adjusted?
is the cable new or has been oiled?
drewps
