March 14, 200916 yr Does anyone know how to replace the ignition points on a 1967 R1 to a modern electonic system?, Is there a company that sells a complete ignition set up? Could I use the Ignition set up from a newer Yamaha Banshee 350 Quad? THANKS
March 15, 200916 yr Does anyone know how to replace the ignition points on a 1967 R1 to a modern electonic system?, Is there a company that sells a complete ignition set up? Could I use the Ignition set up from a newer Yamaha Banshee 350 Quad? THANKS Hi You could try Boyer Branson they used to do loads of kits for all sorts of bikes I've posted a link here: http://www.boyerbransden.com/ Good luck.
March 15, 200916 yr Does anyone know how to replace the ignition points on a 1967 R1 to a modern electonic system?, Is there a company that sells a complete ignition set up? Could I use the Ignition set up from a newer Yamaha Banshee 350 Quad? THANKS Hi there you also have HPI (I use this system on my FS1) here is a link to there site Regards Jim
March 16, 200916 yr Author Hi there you also have HPI (I use this system on my FS1) here is a link to there site Regards Jim
