Posted March 13, 200916 yr help rectifier needed for xvs 125\250. The part number is sh678-11. I've got the egg run on the horizon and the damb thing has died. One of the connector spades has sheered off right down to the base so I cant even get a bit of solder on it to get me through the run. If anyone can help I'd be most obluiged obliged obblijed? any way I'd be made up. Many thanks in anticipation. OGRi Just been hunting around on ebay. There's a SH650D-11 regulator rectifier pattern part there obviously for the 650 version, but does anyone know if it would be ok for the my little 125 draggy. It has the same number of pins and the voltage is the same. Any ideas?
