1993 TZR 125 R ypvs servo
hi all.
this is the first post iv put up on this fourum so im sorry if its no use.
i have just bought a tzr 125 r.
it was a non-runner but i took the carb into work and found the tinyest bit of grit in the pilot jet.
the bike is up and runing fine now BUT......
the ypvs has snaped 2 teeth off a cog in the inside. the cause was seized cables which i should of cheacked.
is it posible to buy the cogs seperatly as the motor ect work fine.
also would a dtr or tzr 250's servos be the same??
help would be much apreciated.
thank you very much :D
a friend of mine has a tzr250 and im near sure the pv servo is identical
