March 11, 200916 yr hi all. this is the first post iv put up on this fourum so im sorry if its no use. i have just bought a tzr 125 r. it was a non-runner but i took the carb into work and found the tinyest bit of grit in the pilot jet. the bike is up and runing fine now BUT...... the ypvs has snaped 2 teeth off a cog in the inside. the cause was seized cables which i should of cheacked. is it posible to buy the cogs seperatly as the motor ect work fine. also would a dtr or tzr 250's servos be the same?? help would be much apreciated. thank you very much
