98 THUNDERCAT MISFIRES
HI I'VE GOT A 98 THUNDERCAT IT'S STARTED MISFIRING AT 6000RPM AT IDLE AND 9000RPM UNDER LOAD (ALL GEARS) AT BOTH TIMES THE REV COUNTER NEEDLE DROPS TO ZERO FOR A COUPLE OF SECS THEN BACK UP?
IT'S A CONSTANT MISFIRE AND WON'T ALLOW THE REVS ANY HIGHER SOME SORT OF INBUILT PROTECTION/FAULT CODE?
I'VE FOUND A THREAD ON ANOTHER FORUM OF SOME ONE WITH THE SAME PROBLEM BUT NO ANSWERS?
ANY HELP REGARDS PHIL
Hi i have a similar intermittent prob with my 98 cat it feels like it only firing on 3 cylinders then the rev's just drop off ive tried all sorts ended up the guy in the bike shop recommended using a fuel additive for carb icing that seems to have done the trick
