March 8, 200916 yr like it says i have a 86 tt600 that quit working last summer. i got it home to find out that the complete ignition system failed stator,cdi,and coil. since then i got the stator rewound got a new cdi, coil, and plug.still wont fire here are the things i do know while kicking i get 200v from stator,4v from the trigger coil,the cdi wants to fire the coil but wont,i tested the coil at work and it does work. pleas help me summer is coming and i cant ride yet
March 12, 200916 yr Author i was reading through the manual and it says it should have around 200v at idle and i was thinking that since it is making 200v while kicking that maybe the stator isn't producing enough amps to fire the coil at slow speeds. let me know if that sounds possible
March 22, 200916 yr Author finally it starts!!!!!!!!!! i found a stator from an 84 klr65o for $25 shipped. then i took it to work opened up the id a little bit then threw it on the mill and drilled the four mounting hols in the right spot bolted it up and the first kick let out a tremendously loud back fire. think a 12 gauge shot gun in a bed room next kick it fired right up. thanks for everybody's help
