FJ1200, Since The Cylinder Cover Is Removed
I had to remove the cylinder cover on my 1986 FJ1200 because three off the bolts were leaking a little oil. Is there anything I should watch for when replacing the gasket and bolt gaskets? Also, is there anything I should check or have checked while I have the cover removed? Thanks for any replies.
If you have the top end apart, it would be well worth checking the valve clearances while they are accessible :D
