February 28, 200917 yr If anyone knows what type and size fuse goes between the positive lead and the rectifier. It would be a big help. 6 volt system. My schematic dosn't show fuse size. Thanks
February 28, 200917 yr If anyone knows what type and size fuse goes between the positive lead and the rectifier. It would be a big help. 6 volt system. My schematic dosn't show fuse size. Thanks Hi There it's a 10 amp fuse you need Regards Jim
February 28, 200917 yr Author Hi There it's a 10 amp fuse you need Regards Jim Thanks Jim, this site helps a lot. all the best: Ken
February 28, 200917 yr Thanks Jim, this site helps a lot. all the best: Ken Hi Ken, not a problem there will be someone here to help you with whatever you ask .. so you have an old RT in the UK we had other modal names & then became the DT (it was AT & CT but I guess the same ) Regards Jim
