R6 does anyone know this part name!!!!help
That is the oil pump cover.
Original part number: OY010125
Alternative part number: 5EB-15416-00-00 (2002 model part number but the part is the same).
In the genuine Yamaha workshop manual it is actually called the "pickup coil rotor cover" as you have to remove this when checkng the valve clearances .Tony.
Are you sure you are looking at the correct part?
Yes if it is the cover highlighted in the red box and held on with seven bolts Yamaha call it the "pickup coil rotor cover" in the genuine workshop manual. I can't see it being called the oil pump cover as the oil pump is accessed after removing the oil sump pan at the bottom of the engine. Maybe if the R6 was a 2 stroke i would agree as Yamaha positioned the 2 stroke oil pump on a lot of their models on the right hand clutch cover at the front. Tony.
