Hello Im New To This Got A Yamaha Tzr 2002 and it doing my head in already :(
to start the bike i have to bump it then it will electric start, if left for and hour it wil need bumping again :/
I Have A new spark plug and recenly fitted a new battery.
Any Help Or Ideas?
could be that the battery acid was mixed incorrectly causing it to loose its charge or there is something else left on which drains the battery.
it doesnt take much to kill those little batteries, e.g. if your brake light switch is loose and the brake light is left on it will flatten the battery within the space of about 5-10 minutes
after leaving it for an hour, check the voltage in the battery using a multimeter, then start it and check the voltage again (should be about 14v with the engine running) to make sure it is getting a charge
