February 25, 200916 yr Hi All, MoT is due at the end of March. Advice from the last one (before I owned the bike) states that the fork seals were replaced, but won't last long because the forks are pitted. I assume that means the chrome is no longer smooth, allowing the oil to seep out of the seal (there's a slight seep now). What can I do to fix this problem in the long term? I'm guessing: 1. replace the fork(s) or 2. get the forks re-chromed Any advice welcome, particularly on approximate costs for re-chroming (if this is the answer). Bike is a 1986 Radian (US import) and I'm in the UK.
February 25, 200916 yr another method, aside from chroming, which depends on the amount of pitting, is to fill the pitting with araldite and then rub down with increasing finer grades of wet and dry paper, this will get the fork syrface back to a smootheness which will prevent the seal leaking. Best to replace the seals if you do this, as the lips of the seal will be damaged. other common bodges is to put a slither of rag under the dust seals to absorb any fluid that gets past the seal or fit 'bellows-style' gaiters (the off-road peeps will know the proper name) so the tester cannot see the leak, doesnt solve the problem, but will get the bike thru an MOT.
February 25, 200916 yr Author even better: http://cgi.ebay.com/ebaymotors/Yamaha-Radi...sQ5fAccessories Seen those - were already in my eBay watch list - cost is a consideration though, so not sure whether it's cheaper to re-chrome?
February 25, 200916 yr Rechroming will cost from about £90 up to £150 depending on who,, what quality you want and the condition of the pitted forks..... More info HERE and HERE
February 25, 200916 yr Author Hi Guys, Thanks for this - looks like it's even stevens for re-chroming v. replacement (Radian specific). I'm guessing these forks are shared with the XJ-600 and FZ-600 (I'll look in the manual when I get home....) - I guess that widens the possibilities for spares. Anyone know if they are shared across other models?
February 25, 200916 yr another method, aside from chroming, which depends on the amount of pitting, is to fill the pitting with araldite and then rub down with increasing finer grades of wet and dry paper, this will get the fork syrface back to a smootheness which will prevent the seal leaking. Best to replace the seals if you do this, as the lips of the seal will be damaged. other common bodges is to put a slither of rag under the dust seals to absorb any fluid that gets past the seal or fit 'bellows-style' gaiters (the off-road peeps will know the proper name) so the tester cannot see the leak, doesnt solve the problem, but will get the bike thru an MOT. Hi , I do MOTs and if I see gaitors fitted to a bike the would not have them I would tend to look into the bike 'in depth' as the tester cannot remove them to check the seals and if one bodge is there it's fair that there are others ! and it could fail on the found ones, but filling the infected areas so the seals are not cut is a good plan, and may work fine for some time but perhaps the ends up point is to fit new fork inner tubes & seals but of course some could be found of an XJ rather then just a YX Regards Jim
February 25, 200916 yr Author Looked at Mr Hayne's manual and the forks look different across the range (manual covers FZ-600, FJ-600, XJ-600, YX-600). Bugger.
March 9, 200916 yr Looked at Mr Hayne's manual and the forks look different across the range (manual covers FZ-600, FJ-600, XJ-600, YX-600). Bugger. From memory the YX & XJ used the same fork inner tubes (but I may be wrong) the outers were different down to the caliper mounting points as the discs were different ... I had an import YX some while ago (the same age as yours) I wonder if it's the same bike !!! Regards Jim
March 12, 200916 yr Author As it happened, it passed the MoT OK, so I will just keep an eye on it. Thanks for all the advice - especially about wemoto - just got a load of oil from them....
March 14, 200916 yr Seen those - were already in my eBay watch list - cost is a consideration though, so not sure whether it's cheaper to re-chrome? To "re-chrome", you'd still need to spend time on them fork tubes first, buffing out the pits. Else, you'd have freshly-chromed tubes, with pits. But, it may be worth your while if you've got other stuff you wanna chrome. Like anodizing and oxidizing, chrome plating is usually done by the lot, not by the piece. A set of fork tubes, or the fork tubes, exhaust, handlebars, and engine covers together...it's all the same price.
