Posted February 22, 200916 yr I am needing help to wire up my front brake to brake light my bike is a XT125 2005. I have two wires that must somehow attach to the brake lever but cannot see where they would go. If anyone can help thanx in advance
February 22, 200916 yr Moderator There will be a switch somewhere on your brake lever, have you looked underneath it?
February 22, 200916 yr Author hi m8 thank you can you tell me what the whare i can get the switch matty
February 22, 200916 yr Moderator Sorry matty I cant, I just thought you would be able to see where the wires plug on to your lever, I'm only guessing though as i havnt got a manual, just have a good old look around especially underneath and you will hopefully see where to fit the wires
February 23, 200916 yr I am needing help to wire up my front brake to brake light my bike is a XT125 2005. I have two wires that must somehow attach to the brake lever but cannot see where they would go. If anyone can help thanx in advance High Matty, Just a thought, If the two "prongs" are not plainly visable under the break lever, It may not have a switch fitted, Have a good look around, You may find fitting holes where a switch should be, Good luck.
February 23, 200916 yr Author High Matty, Just a thought, If the two "prongs" are not plainly visable under the break lever, It may not have a switch fitted, Have a good look around, You may find fitting holes where a switch should be, Good luck. hi m8 think thats the problem cant see anything there there is a hole but nothing in it will have to have a look if anyone knows where i can find the swithch let me know thanx
