I am needing help to wire up my front brake to brake light my bike is a XT125 2005. I have two wires that must somehow attach to the brake lever but cannot see where they would go.
If anyone can help thanx in advance
Sorry matty I cant, I just thought you would be able to see where the wires plug on to your lever, I'm only guessing though as i havnt got a manual, just have a good old look around especially underneath and you will hopefully see where to fit the wires
High Matty, Just a thought, If the two "prongs" are not
plainly visable under the break lever, It may not have a switch fitted,
Have a good look around, You may find fitting holes where a switch
should be, Good luck.
hi m8 think thats the problem cant see anything there there is a hole but nothing in it will have to have a look if anyone knows where i can find the swithch let me know thanx
