Instrument display
Hi all,
due to tumble last year, now having bike repaired and resprayed, have fairing off etc and went to start bike up to turn engine over, noticed Temp gauge needle went straight to top, rev counter not working and backing lights not working, not to mention, dipped and main beam switch in reverse ?!
Is this just a bad earth with front indicators and fairing etc having been removed??
rgds,
John :blink:
sounds just like bad earth!
test it out by running a flying lead from a ground on the cluster straight to the negative of the battery.
Cheers! Will check, when reconnecting newly painted parts!
rgds,
John B)
def bad earth, i had the same problem...... find it fix it ride it ,,,,, ohhhh yeeeaaaarrrr!!
:D
