can anyone help how to de restrict my bike can not find any info anywhere
try using the search function.
I guess it would be re mapping the bike if anything? im not sure to be honest, havnt looked at these bikes that much but you could ask a yammy dealer.
Sorry i was of no real help
There is no restricter fitted to your xt125,it is basically a ttr125 engine.
I have had a rebore done on my xt125, the new piston was from a YBR125 and the gasket set for a 2003 ttr125.
I have also fitted new valve seal's and re-ground the valve's, so the engine has been stripped by me and I can tell you there is no restricter fitted.
As I have said on my reply to your previous post you need to search for bore kit's from a ttr 125 that may fit.
Google "ttr125 big bore kit" and you find over 10,000 result's.
when they built the xt125 they did it to a bit of a budget, so the engine doesnt really have that much potential.
you will be best looking for a big bore kit. an exhaust, air filter and new jets can make some difference, but it depends how much you want from your bike
Tom
