Correct jets? TX500/XS500
I've got a '74 TX500 and since I've never had very good luck with the KEIHIN carbs I went ahead and bought a set of Mikuni 38's from a later XS500 (38mm).
The carbs came with 30-Pilot/122.5-Main, I'm trying to make sure that these are within the range that are suppose to come on the XS500 w/ mikuni carbs.
Thanks!
Thanks!
try here
if they suit the xs500 then they should be ok
try here
I guess they are the right ones :D
Thanks Drewpy. B)
Thanks Drewpy. B)
no probs, the only major change with the 500's was the redesign of the cylinder head AFAIK
