February 13, 200917 yr Last week i Jet washed Yamaha Fazer 1999 model. Right after that oil and petrol warning light come up which prevent me to start Fazer bike, unless i push the bike - have no problem then. i belive, i have electrical problem. anny suggestion?
February 14, 200917 yr Author BIKE stood for a week untouch, it is dry now. Went through all wires, fuses, sparks, look OK. Oil and petrol Full. Lights, Indicators work fine. i believe battery is good. Gears on neutral. you turn the key everything OK, then you press the ignition and NO SOUND/ NOTHING just the oil and petrol light show up
February 14, 200917 yr Moderator Does it have a fuse for the starter motor, I'm not familiar, have you got a manual / wiring diagram? Also make sure the kill switch is off, the bike is in neutral, the clutch is pulled in.
February 14, 200917 yr Jet washing is not a good idea, it forces water in to places that it shouldnt go. (as you found out) Has the bike a side stand switch, this and the engine kill switch are the first places I would check. Good luck. Adam.
February 14, 200917 yr Author Jet washing is not a good idea, it forces water in to places that it shouldnt go. (as you found out) Has the bike a side stand switch, this and the engine kill switch are the first places I would check. Good luck. Adam. the engine kill switch off position, always start off any stand.gear box netural, i tryied pull the clutch nothing at all
February 21, 200917 yr Author the engine kill switch off position, always start off any stand.gear box netural, i tryied pull the clutch nothing at all Went through all cable,check the ignition switch for corrosion,fuses ,socket nothing.Everythig look OK. i wonder maybe cut off starter relay broke? what exactly CDI ignition box do? If the Cut off starter relay faulty, is it possible to start bike either push or press an ignition button?
April 10, 200916 yr Went through all cable,check the ignition switch for corrosion,fuses ,socket nothing.Everythig look OK. i wonder maybe cut off starter relay broke? what exactly CDI ignition box do? If the Cut off starter relay faulty, is it possible to start bike either push or press an ignition button? I may be wrong, but isnt that what happens when u try and start the bike with the side stand down??, Im sure my 2000 fazer does this, could it be the switch??
May 3, 200916 yr I may be wrong, but isnt that what happens when u try and start the bike with the side stand down??, Im sure my 2000 fazer does this, could it be the switch?? i have a 1999 also, there is also a switch on the center stand,sounds to me like one of the stand switches is faulty. ive had mine only about 2 weeks but already finding things that i need to know, someone put mine in gear when i left it over night(i never leave any of my bikes in gear),came down,key in .nothing..went for jump leads thinking battery was flat (locked stearing n thought i had put par lights on too).........luckily i had to move the bike to get it near jump vehicle and ey presto its in gear.......back in neautral and awayshe went!............anyway enough of my stupidity try shorting the two switches so it takes them out of the loop......maybe work maybe im talking crap but its worth a try.
