Thanks for all of the advice so far from this forum- I appreciate it very much.
I have a real problem that I cannot figure out-
The turn signals light up as they should and with the left switch control changes sides perfectly
The problem is they light up but do not flash???? I just puchased a new Flasher Relay thinking that was the problem- same result.
It has to be a wiring issue? Any advice will help. Thanks you Greg
Hi check your flasher bulb wattages are as specification
try with engine revving slightly, may ba a bit low on voltage
How new was the 'New flasher relay'?....Doesnt look like a wiring issue unless the bulbs are dim (dirty / loose ground connection)
