535 Virago Fuse Block
I have an electrical fault that intermittently stops the engine. I am sure the problem is in the fuse block or the wires very close to it. Does anyone know how to slide out the wires & their connections from the fuse block so that I can check for dry joints etc?There is usually a small flap of metal that sticks out on spade connectors, this can be pushed flat with a small screw driver to release the connector from its casing, but I can't see anything like that here. I do not want to damage the block or connectors 'cos that will lead to a lot of trouble and expense.
