cooling fan
HI EVERY ONE
Wonder if any body can help me. I have a problem with my cooling fan? i have a 2003 yamaha fazer 1000 i am having trouble with the radiator cooling fan. When i start the engine after about 20/30 seconds the fan cuts in and continues until i switch off the ignition. I have changed the thermo unit and cooling fan relay and have checked all conectons every thing else seems to check out ok? (PLEASE CAN SOME ONE HELP ME RUNNING OUT OF THINGS TO TRY.)
YOURS
BIGAL
Hiya Al.
This is quite normal and not a problem ,, "they all do that sir" ,,,,,,, with the exhaust being so close to the rad, Yamaha have made it so that when the bike is running the fan cuts in,this helps to keep the things cool and also stops the grease in the head bearings melting,cos it gets quite hot around the headstock ! one way to stop the fan running, is to drop the bike into gear then put it back in nuteral..
BIGAL is that a bisexual girl or a large Allan? :D
BTW :welcome: to the forum
Have done as you suggested and it works fine --many thanks
