February 5, 200917 yr I'm trying to fit a supersprox stealth rear sprocket 47t but they don't do one, so thought mabye a thunder cat one would fit can any one help
February 5, 200917 yr an 05 R1 has 10.5mm mounting holes and so does the thundercat, but the R1 has 130mm between the mounting hole centres wheras the TC has 150mm, the R1 has a 110mm inside diameter as opposed to the TCs' 130mm inside diameter, so the Tc sprocket would be way too big try JT Sprockets, they do a 47T and i use them on my DT, never had any problems http://www.jtsprockets.com/52.0.html?&...uid=2459&p=
February 5, 200917 yr Author an 05 R1 has 10.5mm mounting holes and so does the thundercat, but the R1 has 130mm between the mounting hole centres wheras the TC has 150mm, the R1 has a 110mm inside diameter as opposed to the TCs' 130mm inside diameter, so the Tc sprocket would be way too big try JT Sprockets, they do a 47T and i use them on my DT, never had any problems http://www.jtsprockets.com/52.0.html?&...uid=2459&p= Cheers will give them a go
