Can I fit a rear spocket off a thunder cat to an 05 r1
I'm trying to fit a supersprox stealth rear sprocket 47t but they don't do one, so thought mabye a thunder cat one would fit can any one help
an 05 R1 has 10.5mm mounting holes and so does the thundercat, but the R1 has 130mm between the mounting hole centres wheras the TC has 150mm, the R1 has a 110mm inside diameter as opposed to the TCs' 130mm inside diameter, so the Tc sprocket would be way too big
try JT Sprockets, they do a 47T and i use them on my DT, never had any problems :)
http://www.jtsprockets.com/52.0.html?&...uid=2459&p=
Cheers will give them a go
