R1 Key recode sequence, Help?
Does anyone know the correct sequence to recode the two black keys from the red code re-regestering key?
Cheers
I've a Tenere, and the re-code sequence is 8 pages long and pretty complicated, given that a screwup will cost you in the region of £1K I'd suggest going to the dealer.
I'll try to extract the part of the document, but it looks like the PDF (workshop Manual) is locked - Even then this is for a Tenere so miht not work, I'd imagine it's the same sequence though.
How old is your Bike? This R1 is on a 56 plate
2008 - the returning legend......
<---- Just over there
I would like to see the PDF manual if you could, would be a big help
